Old July 2nd, 2008, 06:37 AM
jameselliott is on a distinguished road
Default Super Capacity 465 Model RF386
My whirlpool range SC465 Model RF386PXG is not cooking properly. The oven is not holding temperature consistently. For example; set temp to 350 and the oven says it reached 350, but thermometer test has shown 310. I think that is a little more than the +/- 10 degrees. I have replaced the sensor. with no result. I used the temp offset with a marginal difference. Is there anything else that I can check or replace to fix the condition?
Old July 2nd, 2008, 08:20 AM
Hi James,
If you've replaced the oven sensor and its still giving you the same problem, then the only other part that would cause this is your electronic clock oven control board assembly.
There should be another letter and number after the G at the end of your model#.
If you can post that, I can find you the cheapest one you can order.
Old July 2nd, 2008, 09:11 AM
Yes the Model # is RF386PXGB. I should also say that they oven is very slow to heat up as well. Thansk for the assistance.
Old July 2nd, 2008, 09:43 AM
There should be one more number after the B
I get these results:
RF386PXGB0
RF386PXGB1
RF386PXGB2
RF386PXGB3
RF386PXGB4
Does the bake element turn red when its heating up?
Old July 2nd, 2008, 09:56 AM
the number after the model is 1.
The element does turn red while heating up.
Old July 2nd, 2008, 10:18 AM
Here's the cheapest price I found for your electronic clock control board:
Manufacturer's Number: 6610179
icon
How old is your range?
Old July 2nd, 2008, 10:29 AM
it is about 8 years old. are you thinking warranty on that type part?
Old July 2nd, 2008, 10:41 AM
No, because the warranty is only for 5 yrs. on that part.
I was thinking about the cost of that part relative to the age of your range. Usually you don't want to start dumping big money into a 8-10 yr. old range if you have a big family living in your household and use it daily or many times a day.
Whirlpool Super Capacity 465, Model SF365PEGT jsw6511 Whirlpool 3 November 3rd, 2007 12:27 AM
WhirlPool super capacity 465 - Model No.SF325PEGQ boibloo Whirlpool 1 September 30th, 2007 06:09 PM
Glass Top Super Capacity 465 - HELP crucialjames Whirlpool 1 July 25th, 2007 08:38 AM
Whirlpool Super Capacity 465 Model SF362BEGQ0 Oven overheated Mark1965 Whirlpool 1 July 2nd, 2007 03:43 PM
Whirlpool super capacity 465 gas oven not lighting magna8385 Whirlpool 2 February 6th, 2007 03:36 PM
