Old July 11th, 2008, 08:16 AM
sagashi is on a distinguished road
Default DU1100XTP Detergent Dispenser
The detergent dispenser quit opening during the wash cycle. Here's what I found when I took the door off.
The plastic has actually melted away from the back of this little motor, and also through the rubber cover that protects the dispenser assembly.
It seems like water leaked down from the air vent and caused this.
I guess I need to replace the dispenser assembly. Is that the only part I"ll need?
How can I prevent this from happening again?
Sagashi
Old July 11th, 2008, 10:42 AM
Hi Sagashi,
There should be another letter & number after the P at the end of your model#.
Your model# tag should be located inside the dishwasher on the top as you open the door, or on the inner right or left side walls.
You'll need a new air vent gasket and dispenser, I will link you to the parts when you post the complete model#.
Thanks.
Old July 11th, 2008, 10:49 AM
Du1100xtps1
Old July 11th, 2008, 11:08 AM
Here's the parts diagram:
You'll need vent gasket#6
Manufacturer's Number: 8269259
icon
icon
icon8269259
And dispenser assembly#8:
Manufacturer's Number: 8558129
icon
icon
icon8558129
Old July 16th, 2008, 04:39 AM
Default Still not fixed...
Well, we got the new parts, but the detergent dispenser still won't open. What should we try next?
Sagashi
Old July 16th, 2008, 07:26 AM
Ok, then it sounds like it shorted your control board as well.
Manufacturer's Number: 8564546
8564546
Kitchenaid Dishwasher Detergent Dispenser Spring cindyet KitchenAid 9 April 23rd, 2008 10:29 PM
Detergent Dispenser Issue ssruindia Whirlpool 3 July 29th, 2007 07:10 PM
SHU3002 detergent dispenser replacement Lucianp Bosch 0 April 25th, 2007 07:20 AM
Detergent Dispenser Door Won't open AndreaH Sears Kenmore 1 October 9th, 2006 11:59 PM
Detergent Dispenser Problem - Door Spring help lroberts Whirlpool 3 August 20th, 2005 06:38 AM
