Old July 15th, 2008, 07:32 AM
t-o-double-d is on a distinguished road
Default Whirlpool Quiet Partner III Gold Door Leak Model DU1050
Greetings,
I have been experiencing a door leak on my dishwasher for the past few weeks. When I feel under the door in the insulation it is soaking wet on the left and right sides. I tried running it empty with 2 cups of vinegar and it didn't leak as much. Then tried using dishwasher detergent (powdered) and a sponge and scrubbed the area around the hindge which seemed to help a little bit. Sometimes it leaks on the left side but not the right and seems to leak more when I have it loaded with dishes. Any ideas on what it might be and how to resolve?
Todd
Old July 15th, 2008, 09:19 AM
Hi Todd,
Remove the outer door panel by removing all those hex screws on the inner door. Then that panel slides up and out.
Then you can get a better view of where its leaking at.
Old July 17th, 2008, 06:23 AM
Hi Jake, after removing the outer door panel it looks like the water is splashing out the bottom of the door. Seems to be a lot of buildup at the bottom of the door (is that the vent area?) When it runs I can see water splash at the bottom left corner. I tried to remove some of the crud and it leaked less, perhaps my hard water is taking a toll on my dishwasher and causing buildup? Seemed to be soap residue and maybe mineral deposits.
Old July 17th, 2008, 08:59 AM
Your vent is at the top of your door.
You might want to buy this:
Removes built-up soap scum and discoloration due to iron and other water impurities. Also works great in washing machines, porcelain sinks and porcelain tubs.
Glisten Dishwasher Cleaner and Deodorizer
And see if that clears up the problem.
Old July 17th, 2008, 10:07 AM
Cool, I'll pick some up and give it a try.
Todd
Old July 17th, 2008, 10:47 PM
Sounds good Todd.
Old July 21st, 2008, 08:28 AM
I ran glisten through the normal cycle twice and it is not leaking as much from the bottom left corner. Seems to still be splashing a little over the edge when it runs. Any ideas as what I could try next?
Thanks again for all help and advice.
Todd
Old July 22nd, 2008, 12:20 AM
Whats the complete model# of your dishwasher? DU1050 is just a partial#
The model# tag should be located inside your dishwasher on the upper walls of your inside tub, they I can see if it has a splash guard on your model.
Old July 22nd, 2008, 04:55 PM
The model number is actually GU2400XTPB3. Thanks!
Old July 22nd, 2008, 10:36 PM
I don't see a splash guard on your model.
I'm not sure whats continuing to cause the water leak, next time it leaks open the door to see if any suds are in the tub with the water.
[FIXED] Whirlpool Gold Quiet Partner IV - control panel issues BobP Whirlpool 19 April 9th, 2008 09:43 PM
Whirlpool Quiet Partner III Stuck at Specific Cycle Time ash807 Whirlpool 12 February 27th, 2008 10:13 PM
WHIRLPOOL Quiet Partner III malcolj Whirlpool 1 November 19th, 2007 11:21 AM
How do I remove the food grater from a Whirlpool Quiet Partner III? craniac@gmail.com Whirlpool Brands Forum 2 May 24th, 2007 04:56 PM
Whirlpool Quiet Partner III Dishwasher Skipping Wash Cycle BitterEpiphany Whirlpool 4 October 13th, 2006 11:29 PM
