Old July 15th, 2008, 05:10 PM
Mav1972 is on a distinguished road
Default Super Capacity 465 model SF315PEGW5 oven not functioning
It all started after I purchased a house and found that the oven does not work. The stove top is perfect and all igniter's work along with a flow of gas. The control panel appears to be fine, and when I selected the bake option, the preheat/Start display flashes. But no heat. I do get a PF error after unplugging the unit, but this appears to be normal indicating a "Power Failure". So looking into the broiler part, I couldn't see that the igniter was glowing. Ok, so I bought a new igniter without first testing the volts. The new igniter came the other day, put it in, and still nothing. Thanks to the internet, I found this site, and started to troubleshoot with only a volts meter. Testing the power, I'm only getting a few volts out of the wires to the igniter. So the igniter is good, but no power. I cannot see any type of fuse to replace and all the wires look good. I have looked at some link you supplied for troubleshooting, but I'm not sure on how to test the OHM's thing. I guess if I understood, I could determine if it is the gas valve " as indicated in other forums" before I go out and drop over a hundred dollars.. Any help would be greatly appreciated.>>
Old July 15th, 2008, 06:45 PM
You'll need a new electronic clock/oven control board.
Here's the cheapest one I found for your model:
Manufacturer part#6610152 is RepairClinic item#675669
6610152
Old July 17th, 2008, 01:27 PM
Thanks for your help.. I ordered a new one today, and should have it by next week. Hope this helps.
Old July 18th, 2008, 12:48 AM
Sounds good Mav,
Let us know the outcome.
Old July 22nd, 2008, 10:13 AM
Thanks Jake, that did the trick.. The "start" button was bad on the old control board.
Again, thanks for all your help.
Old July 22nd, 2008, 05:41 PM
Excellent Mav, good job fixing it.
WhirlPool super capacity 465 oven not working. Repair Manual JSPerdomo Whirlpool 16 January 6th, 2008 04:11 AM
Whirlpool Super Capacity 465 / Gas Oven jeff_465 Whirlpool 4 November 25th, 2007 02:26 AM
Whirlpool Super Capacity 465 Model SF362BEGQ0 Oven overheated Mark1965 Whirlpool 1 July 2nd, 2007 05:43 PM
Whirlpool super capacity 465 gas oven not lighting magna8385 Whirlpool 2 February 6th, 2007 05:36 PM
Electric Super Capacity 465 - Oven LED "LOC" (Oven door will open but won't heat) marcum03 Whirlpool 1 September 29th, 2006 11:41 AM
