Old September 2nd, 2008, 04:46 AM
jon_roanoke is on a distinguished road
Default Whirlpool GU1500 intermittent top rack issue
Greetings. I have a GU1500 that has been giving me grief for months. Started out with the standard top rack cleaning problems as discussed elsewhere in this forum. If I cleaned the chopper screen, it would be good for 3-5 loads and then start again. This happened a few times.
I next replaced the check valve - this time it worked well for approx 15 loads of dishes and now the problem is coming back again. Right before the problem reoccured this last time, it was making an unusal grumbly noise as it ran. Not loud, but noticable. I hate to replace the pump/motor if not necessary. Would appreciate any help you can offer.
thank - Jon
Old September 2nd, 2008, 09:23 AM
Hi Jon.
Yea, unfortunately it sounds like you will need to replace the motor assembly, or the complete sump/motor assembly(easier, but more costly, but recommended more).
Whats the complete model# of your dishwasher? Its located inside your dishwasher on the upper tub wall.
I'll get you the cheapest price for both.
Old September 2nd, 2008, 09:37 AM
The sticker is gone, but I belive it is a GU1500xtkq0
Do you know why replacing the check valve worked for a few weeks?
Thanks - Jon
Old September 2nd, 2008, 02:56 PM
It may have worked awhile, something may be lodged in your sump assembly down were your motor impeller is at.
Your probably going to have to remove the wash motor assembly itself, to see if something is lodged in there.
Start reading at Page#20 here:
It will show you how to remove the pump and sump assembly, then the wash motor.
Here's the cheapest price I found on your wash motor assembly, if you need to order it:
8534942
Here's the sump assembly for your model:
Manufacturer's Number: 8535150
8535150
Old September 3rd, 2008, 09:57 AM
Thanks Jake. Just pulled it partially apart and the chopper screen is packed with food particles again.
Added: I tried to remove the bolt holding on the motor and shield, but can get a tool all the way back under the shield to reach the bolt. I just ordered the complete sump assembly. I figure I will still need to remove that bolt - any suggestions?
thanks - Jon
Old September 3rd, 2008, 06:40 PM
No, with the complete sump assembly, everything is completely assembled. So you shouldn't have to worry about that bolt.
jon_roanoke (September 5th, 2008)
Old September 5th, 2008, 08:05 AM
Jake, is there a guide, preferably pictoral, that walks you through replacing the pump and motor assembly? Thanks - JPolk
Old September 5th, 2008, 09:51 AM
Well I got the sump/pump replaced, but now I have a leak on the side of the tub. Water is seeping out from behind the water inlet assembly. I disconnected it and reseated the gasket, but still it leaks. Help Please!
Old September 5th, 2008, 12:18 PM
I continued to monkey with the inlet gasket. What finally worked was flipping it inside out. It must be worn on the outside.
Just finished running a cycle and no leaks. Now I'll try with the dishes.
Old September 5th, 2008, 01:19 PM
Good job, sounds like you got it.
Tags
whirlpool gu1500 top rack
Kenmore Elite top rack wheel replacement jgalecki Sears Kenmore 1 March 7th, 2008 05:28 PM
Whirlpool Top Freezer - defrost can't exit alank2 Whirlpool 9 January 19th, 2008 05:08 PM
Replacing Top Rack Of Kuds220t klinger KitchenAid 3 July 30th, 2007 11:22 PM
Noisy upon start, Not cleaning Top rack coach_dorsey Sears Kenmore 3 June 11th, 2007 08:59 AM
Whirlpool Quiet Partner II DUL200PKQ1 - adjustable top rack oneder Whirlpool 0 January 16th, 2007 07:57 AM
