Old September 10th, 2008, 08:36 PM
l8nighter1 is on a distinguished road
Unhappy Quiet IV blowing control fuses
Jake, I am getting very frustrated with my QP IV, Model GU1500XTLS3, I bought it 3 years ago and 4 months ago it stopped in the drain mode I believe (it had an inch of water in the tub). I called the repair folks, they came out and troubleshot it to the panel, they changed that. It wroked for about 3 weeks and did the same thing... The repair man siad it would be 90.00 each time he came out but the parts would be free since it was under warranty... decided to do the work myself. I found the fuse blown on the control board and I noticed what appeared to be one of the caps on the board had a "bulged top"... so I bought the control board. It workd about a week, same problem. I found a local place to get the fuse and the counter guy suggested the active vent could be the problem as he had a customer that sounded similar and he bought a vent and he never came back... well I order the vent on line and changed that... it is in the same state... no power... cna you help me understand what is blowing the fuse on the control board... it can't be the vent, the board, or the panel as they have all been changed?
Thanks, Dave
Old September 10th, 2008, 09:16 PM
ApplianceJunk's Avatar
Did you get two new wires in the same parts bag as the new thermo fuse?
If so did you change the wires too.
Often times its a bad connection on one of the spades that plug into the fuse that create heat and make the fuse blow. This is why you get two new wires with the new fuse.
Old September 10th, 2008, 10:20 PM
Yes, AJ is correct, the thermal fuse will keep blowing unless you replace the wires that come in the kit.
Here's the cheapest one I found for your model:
Manufacturer's Number: 8193762
8193762
Old September 11th, 2008, 08:22 PM
Thx, I will try that... and let you know what happens...
Old September 11th, 2008, 10:39 PM
Ok, sounds good Dave.
Repeated problems with Quiet Series 300 control board/panel QuietSeries300Lemon Maytag/Magic Chef/Admiral/Jenn-Air 67 June 19th, 2009 11:43 PM
[FIXED] Whirlpool Gold Quiet Partner IV - control panel issues BobP Whirlpool 19 April 9th, 2008 10:43 PM
Maytag Quiet series 300 Control panel superbond Maytag/Magic Chef/Admiral/Jenn-Air 2 March 11th, 2008 01:45 PM
Quiet Partner III Control panel issues Markb Whirlpool 9 December 1st, 2007 12:53 AM
Maytag Quiet Series 300 Dishwasher - Control Panel Dead Hookem Maytag/Magic Chef/Admiral/Jenn-Air 3 November 18th, 2007 05:25 PM
