Old September 22nd, 2008, 05:28 PM
chavezone is on a distinguished road
Default [FIXED] Whirlpool GU2600XTPS1 clean LED flashing 7 time's
Hello Jake or any other pro that I fail to mention
Nice forum first and foremost. I hope you can help me out with my issue.
I found by doing a search of the forum that the flashing light meant that my heating element had gone.
I went to a local parts store to ask about the heating element and the tech told me to use a volt meter tester on the element to test it for continuity, I just dont have the slightest clue on hoe to use my voltmeter, he told me to set my meter to ohm's and touch one each of the elements plugs that are coming out the underside of the d/w.
I just need to know how exactly to do this, does the d/w have to be plugged in, or what??? sorry if I Sound dumb because I feel dumb
and after doing this the right way what am I looking for, when I do it now with unit unplugged the meter reads numbers in the 40.00 and quickly drops down to zero
Old September 22nd, 2008, 08:14 PM
No, make sure your breaker to the dishwasher is off before you ohm the heater.
This link shows you how to use a ohm meter:
http://www.applianceaid.com/electric...ting_tips.html
A good heating element will read 30 ohms or less, make sure you take 1 wire off the heating element first before you ohm it out.
Here's the heating element for your model:
Manufacturer part#W10134009 is RepairClinic item#1381534
W10134009
Old September 22nd, 2008, 10:09 PM
Thanks for the super quick response, I went ahead and reattached one wire to the heating element and tried to ohm it and I did get a reading this time, I got 13.4 ohms on the 200 setting on the meter, so it looks like my element is still good, do you have any idea what else it could be?
Thanks again
Old September 22nd, 2008, 10:46 PM
Then its the control board thats bad.
Here's the control board for your model you can order:
Manufacturer's Number: 8564546
8564546
The inner door liner screws for the console just unscrew then you have access to your control board, it mounts with plastic clips that you use a screwdriver to pinch the clips and the control board comes out.
Here's the repair manual for your model, you can print it out, it explains everything on how to do it:
The new control board doesn't come with that white thermal fuse, simply unsnap it from your original control board and snap it in the new one.
Old September 23rd, 2008, 05:41 AM
Great
Is the reading that I got of 13.4 ohms good, you mentioned that they are usually 30 ohms or less
Old September 23rd, 2008, 07:39 AM
Yes, 13.4 ohms means its good.
Old September 26th, 2008, 05:53 PM
Unhappy
Jake Thanks for the help with my issues but sadly after replacing the board with the new control board it runs for about 20 mins then shut off, if I start it the timer reads 96 mins it runs until around 65 mins remaining, I'm not sure what time exactly it shut down. I looked at it with 65 mins left and a few mins later it was off and the clean light was again flashing 7 times. Any Ideas also on the website that you referred me to it says I can return parts, do you think I will be able to return the control board if my old one is still good?
Old September 26th, 2008, 10:11 PM
Hmmm, thats very strange, the control board should have fixed it if the heating element is good like you tested.
You can return the control board here:
http://www.appliancepartspros.com/cu...e/returns.aspx
Old September 26th, 2008, 10:53 PM
can you tell me what the steos are after installing the board, heres what i did, after installing the board i plugged in the machine,then i did a factory reset by pressing the sequence of buttons,after that i ran it thru a cycle and thats when it started with the problem again,do you think i should get the haeting element and replace that before returning the control board
Old September 27th, 2008, 08:39 AM
Yes, it would be good to order the heating element before returning the control board.
Feel the heating element inside, do you feel pits or bumps on it?
chavezone (September 27th, 2008)
Tags
gu2600xtps1
GU1500XTLB2 with clean led blinking 7 times wyandotford Whirlpool 3 November 30th, 2007 09:00 AM
whirlpool GU2400XTPB3 clean light on lsparkie Whirlpool 2 October 15th, 2007 06:03 AM
Whirlpool GU1500XTKB0 did not clean Tedd Whirlpool Brands Forum 3 February 4th, 2007 09:33 AM
Whirlpool Quiet #1 (DU1050XTPQ3) clean won't stop flashing terry.bowers@gmail.com Whirlpool 12 December 17th, 2006 06:51 PM
Whirlpool Quiet Partner I DU1055XTPS3 - clean light flashing dazedandconfused Whirlpool 1 December 13th, 2006 12:11 AM
