Keeps Running, stuck on 39 minutes
I have a dishwasher that has started to act up after 2 years of flawless operation. It's a Whirlpool GU2500XTPB6. It never gets out of the wash cycle. The minute display stays on 39 minutes and it never moves, it just keeps running. One time I let it run 1.5 hours to make sure it really was stuck. If i stop it it, it will drain and the dishes are then clean. Any suggestions as to where I should start?ffice ffice" />Last edited by DonBrookes; September 30th, 2008 at 04:51 AM.. Reason: typos |
Here's the tech. data sheet for your model: https://www.servicematters.com/docs/...%208535451.pdf Possibly a bad heating element or control board. You can run a diagnostics test, run it through twice and at the end of the 2nd time, feel just above your heating element to see if its hot. SERVICE DIAGNOSTICS CYCLE NOTES NOTE 1. To start the Service Diagnostics Cycle, press the following keys, in order, in less than 6 seconds, while in standby: Heated Dry, Normal, Heated Dry, Normal Report back what you find. Jake |
DonBrookes (September 30th, 2008) | ||
Hi Jake,
That was cool, I ran thru the diagnostics and it here are the numbers it displayed: 88, d2, 12, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6 ( |
Ok,
You would need to ohm your heating element for continuity, a good element should show 30 ohms or less. Make sure the breaker is off to your dishwasher first. Its likely the electrical terminals are in the very back, so you'll likely need to pull your dishwasher out to ohm the heating element. Take the heating element wires off first before testing the element for continuity. But first feel your heating element all around inside your dishwasher, if you feel bumps on it or pits in it, its definitely your element thats bad. Here's the heating element for your model: Manufacturer part#W10134009 is RepairClinic item#1381534 W10134009Jake
Thanks for the quick response. I will do as you suggest and get back to you with how things went.
Hi Jake,
I pulled the dishwasher out and removed the heater element leads and tested the element. I am getting between 10 & 11 OHM's. You said less than 30. I read the article about typical ohm readings and it sounds like this reading is too low. So i think i will order the coil. What do you think. |
Yes, that seems abit low, I'd order the heating element.
| Tags |
| keeps running |
| Quiet Partner III Fills/Drains but Does Not Wash | MangoGT | Whirlpool | 6 | November 9th, 2008 10:07 AM |
| Quiet Partner III Drain / Heater Problem | alohatech | Whirlpool | 1 | May 1st, 2008 05:06 PM |
| Quiet Partner III: Does not clean upper deck | sahassio | Whirlpool | 1 | August 12th, 2007 11:55 PM |
| Quiet Partner III - Blinking Light and no action | donewithwhirlpool | Whirlpool | 10 | July 7th, 2007 10:18 AM |
| Quiet Partner III - how do you slide it out? | Willie | Whirlpool/KitchenAid | 9 | January 17th, 2007 01:26 PM |
