Old October 8th, 2008, 12:38 PM
hametown is on a distinguished road
Default Whirlpool RBS245 won't heat after autoclean
I have a Whirlpool RBS245 oven. We just ran the self-clean mode (successfully) and now no heating functions work at all. Any ideas? Thank you
Old October 8th, 2008, 04:59 PM
RBS245 is just a partial model#, please post the complete model#, the model# tag is usually located either inside the door on the inside frame or on the very bottom of the frame.
Is this oven Gas or Electric?
Old October 8th, 2008, 07:09 PM
Default Whirlpool full model # not heating
Thanks, Jake - the full model number is RBS245PRS00 and is elcectric. thanks
Old October 8th, 2008, 10:49 PM
I would first check your safety thermal thermostat, its #37 here:
You'll need to pull your oven out from the wall, then take off the back access panel, then you will need a volt/ohm meter, then take off the wires to it, and ohm it for continuity.
Unplug or turn the breaker off to your oven first before testing that safety thermal thermostat!
You can get a cheap volt/ohm meter at Radio Shack.
Here's the safety thermal thermostat for your model:
Manufacturer part number 9759243 is RepairClinic item number 1061376
9759243
Old October 9th, 2008, 04:46 AM
Thanks, Jake. I'll give it a shot.!
Old October 9th, 2008, 08:21 AM
Whirlpool RBS305PDQ10-No Heat on any setting rexcars27 Whirlpool 7 January 24th, 2008 05:48 AM
Heat goes out on my Whirlpool LGQ8000HQ0 gas dryer oldtoys1961 Whirlpool/KitchenAid 3 November 28th, 2007 10:54 PM
Whirlpool Electric Range shorted out half my apartment and now does not heat Gargy30 Whirlpool 1 July 29th, 2007 09:57 AM
Whirlpool gas dryer, no heat, new coils etc.. zagato64 Whirlpool/KitchenAid 5 November 5th, 2006 11:26 PM
Whirlpool oven very slow to heat up albritton Whirlpool 10 November 3rd, 2005 10:16 AM
