Old November 9th, 2008, 08:04 AM
Team Irish is on a distinguished road
Default GU1200XT not getting dishes clean
I have a Quiet Partner GU1200XT that I bought from a neighbor that is not getting the dishes clean. It leaves food and a residue on the dishes.
I checked the spray arms which seem to be fine. The water is getting very hot and the pressure in our house is very good.
Last month I replaced the check valve and the chopper, but this hasn't helped.
What else could be wrong?
Old November 9th, 2008, 08:23 AM
GU1200XT is just a partial model#, whats the complete model#? The model# tag is located inside the dishwasher on the upper tub walls.
Sounds like you will need a new motor. Whirlpool had a few issues on that model with the motors.
You can order just the motor alone, or the motor/sump assembly which is higher in price, but easier/less steps to install.
Old November 9th, 2008, 09:10 AM
Full model number is GU1200XTKQ0
Many thanks,
Jillian
Old November 9th, 2008, 10:00 AM
Here's the sump/motor assembly for your model:
Part#8535150
Here's the motor alone:
Part#8534942
Here's the repair manual for your model, it explains how to change both:
Old November 9th, 2008, 10:20 AM
Thanks Jake. How much harder is installing just the motor? My husband and I are both quite handy.
Many thanks,
Jillian
Old November 9th, 2008, 01:04 PM
Its not to much harder, just takes more time and abit more involved, but if you follow the instructions in the repair manual, you should have any problems.
Old November 14th, 2008, 09:01 AM
Is there a way I can tell for sure if it is the motor?
Many thanks,
Jillian
Old November 14th, 2008, 09:30 AM
Sometimes, check the motor impeller, does it look worn out or beat up? Is the motor impeller stripped from the motor shaft, free turning on its own?
Old November 16th, 2008, 03:22 AM
The motor impeller looks fine and it turns freely.
Many thanks,
Jillian
Old November 16th, 2008, 08:16 AM
Ok, from my experience on these models, installing a new sump/motor assembly usually fixes the problem 95% of the time.
If you order the sump/motor assembly from the link I posted above and install it and it doesn't fix the problem, you can return it within 30 days for a full refund.
Tags
dishes not clean, gu1200xt, whirpool quiet partner
Dishes not clean...help needed mattr KitchenAid 3 November 11th, 2007 09:19 AM
Frigidaire Gallery won't clean dishes Hey_mo Frigidaire/Electrolux 1 March 1st, 2007 09:41 PM
665.17362301 Not getting dishes clean JerryL Sears Kenmore 7 January 5th, 2007 10:34 AM
Elite 665 not getting the dishes perfectly clean Bonthron Sears Kenmore 1 September 17th, 2006 10:40 PM
Kitchenaid - dishes on top rack are not getting clean jbollinger KitchenAid 3 September 5th, 2006 10:38 AM
