Old November 9th, 2008, 06:32 PM
morph860 is on a distinguished road
Default [FIXED] Quiet Partner I: Doesn't drain
Been having some issues with my dishwasher. It's about 2 and a half years old now. Was having issues with it draining. Replaced the drain hose, and it worked fine for a while. Stopped working a few days ago, just got around to replacing the hose for a second time. Still doesn't work. When I pull the drain house off, all of the water leaks out - so I don't think anything is clogged. I also tried vacuuming all of the water out, and running a fresh cycle - still doesn't drain.
The people that I bought the house from installed a laminate wood floor - so I would need to remove the floor or the counter in order to remove the dishwasher.
Is there anything I can try without removing? I can access some of it from the bottom, but it's hard to reach much farther than where the drain hose connects.
The guy at Home Depot told me to try Drano - but that doesn't sound like a very good idea.
Thanks in advance,
Brian
Old November 9th, 2008, 06:37 PM
Model number is DU1048XTPQ4
Old November 9th, 2008, 07:08 PM
Hi Brian,
Something may jammed in your drain motor impeller, or your drain motor bearing is locked-up.
Page 21 here shows you how to take apart the drain motor:
Here's the drain motor for your model in case you need to order it:
Manufacturer's Number: 661662
If your drain motor is fine, then something in your sump is blocking the flow of water out.
Start with first checking the upper part of your sump assembly before pulling it out. Check your chopper screen and black rubber check valve.
From the repair manual link I posted a link to above read Page 17 Read 1-4 where it says this:
Lower Spray Arm
It shows how to get access to the chopper screen and check valve.
morph860 (November 10th, 2008)
Old November 10th, 2008, 09:09 AM
I'll give it a shot.
Thanks.
Old November 10th, 2008, 09:46 AM
Ok, sounds good, let us know the outcome.
Old December 7th, 2008, 05:37 PM
Ended up being a clog in the disposal. Wasn't allowing any water to get through.
Everything is good now.
Old December 7th, 2008, 10:20 PM
Goog job finding it was the disposal, thanks for the update.
Quiet Partner I will fill and drain but won't wash psrome Whirlpool 9 October 21st, 2008 03:26 PM
Quiet Partner III Drain / Heater Problem alohatech Whirlpool 1 May 1st, 2008 05:06 PM
Quiet Partner skipping drain cycle Geof Whirlpool 3 December 7th, 2007 09:13 PM
Quiet Partner III Doesn't Drain - Dead Ed Abbey Whirlpool 7 May 20th, 2007 10:49 AM
Whirlpool Quiet Partner II - Doesn't drain and leaking Shooter Whirlpool 3 May 2nd, 2007 09:34 AM
