Old November 22nd, 2008, 07:21 AM
Larry80 is on a distinguished road
Default Intermittent PF GBD307PDS7
Getting intermittent PF code on Whirlpool double oven Mod GBD307PDS7.
PF occurs about an hour into cooking. Oven goes off then resets after 10 seconds. Then frequency is every couple minutes. Happens on upper and lower oven. Replaced upper thermal fuse 4 years ago. When it went there was no power to upper oven at all. Any ideas?
Old November 22nd, 2008, 12:51 PM
Only 1 of 2 things would cause the PF(Power Failure) error code.
1. You have a loose connection at your terminal block were your main power connects to the oven, I would check that first, make sure your turn the breaker off to your double oven first. Make the nuts are tight on the terminal block.
Here's the tech data sheet that shows you were all the parts are:
https://www.servicematters.com/docs/...%208301761.pdf
2. If the terminal block is fine, then its your control board.
Here is the control board for your model:
Part#8302967
kcms135hss-0 intermittent reduck Whirlpool/KitchenAid 6 June 16th, 2008 09:50 AM
intermittent rattle typhoon55 GE/Hotpoint 4 May 4th, 2008 08:09 AM
Intermittent Issues with Oven scoobydoodt Whirlpool 5 May 14th, 2007 12:24 PM
Whirlpool Range Intermittent Ignition itasca82 Whirlpool 3 December 20th, 2005 04:22 AM
intermittent pump problems on kenmore washer cheyenned Sears Kenmore 4 August 20th, 2005 08:21 PM
