I'm having problems with my whirlpool model # Gu1200xtkqo and from what I've researched so far I'm going to take some advice I've seen
Jake give about changing out the check valve. I've been following a picture illustration of Jake's and now I'm stuck because I can't figure out how to get the last cover off, its the one above the check valve and the chopper. Any help would be much appreciated, thanks! Just so you know my main problem it is that my washer will not do the wash cycle. I hear it fill with water, then it makes noise like it is trying to wash, then it just sits idle. After being idle i will hit the drain button and it drains fine. |
I think I found where Jake has responded to this before, I guess I should have researched more.
Were you able to get the chopper cover off?
In post#6 here: KitchenAid fills with water. Wash light blinks. Chopper cover removal help too! Tells how. And post#2 here: kenmore dishwasher 665.16024401 Parts are included to order as well if you need them. Jake
Yes I was able to get the cover off following the advice you have previously given. The chopper did spin freely and there was not very much "trash" on the chopper screen, but I have ordered a new chopper and check valve. Will post again after I have installed new parts. Again, thanks for the help!
Ok, sounds good.
okay, the new parts have arrived- chopper & check valve. When inspecting my old chopper I don't really see anything wrong with it. The problem I am now having is how do you take the chopper off. Do the couplers just seperate from each other with the use of pliers. Also I'm wondering if I should just leave the old chopper in and just change out the check valve. Any suggestions?
sorry for posting too soon, I got the chopper off. will update after new parts installed & running.
Yes, its a little tricky to get off, glad you got it.
![]() Yes, please keep us posted. Jake
okay I changed out the chopper and check valve, still the same problems. Just to let you guys know when i changed the chopper the shaft on the motor did spin, it was not seized up. i've gone about as far as i think i can without bringing in a technition, unless you guys have anymore advice. Again thanks for your help Jake!
Ok, then its likely you will need a new wash motor or sump/motor assembly.
Here's the cheapest price I found on your wash motor assembly: Manufacturer's Number: 8534942 Here's the sump assembly for your model: Manufacturer's Number: 8535150 The sump/motor assembly costs more, but easier to install. Start reading at Page#20 here: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf It will show you how to remove the pump and sump assembly, then the wash motor. Jake
| [FIXED] Kenmore Dishwasher goes to next cycle before water full | jgaines | Sears Kenmore | 42 | May 15th, 2008 07:23 PM |
| Whirlpool GU1500 chopper/check valve ??? | hates-doing-dishes | Whirlpool | 7 | December 6th, 2007 09:06 AM |
| KitchenAid Cleaning and Check Valve | geo | KitchenAid | 5 | November 19th, 2007 10:25 AM |
| How do I remove chopper cover? | staffman50 | Sears Kenmore | 5 | January 26th, 2007 10:51 PM |
| KUDM01TJBT0 Kitchenaid Check Valve problem | bhenders52 | KitchenAid | 2 | November 3rd, 2006 10:34 PM |
