Old December 4th, 2008, 10:55 AM
aaelliott is on a distinguished road
Default [FIXED] Bad Oven
I have a SC 465 oven that is not working, broiler and stove top are working, glow bar on bottom not lighting, Can any body give me the next step on what to do. Serial number RG4912773 Model SF360BEEQ
Old December 4th, 2008, 07:20 PM
You can do 1 of 2 things, since your broil igniter and bake igniter are the identical part# you can switch the 2 and see if the oven comes on.
Or you can get a volt meter to see if you have 120 volts at your oven igniter connector with the oven on.
Here's the oven/broiler igniter for your model, in case you ever need to order it:
Manufacturer's Number: 4342528
aaelliott (December 5th, 2008)
Old December 5th, 2008, 07:32 AM
Default Yea it works
I switched the igniter, and it works!!! Thank you so much for your help. My husband will be happy to know it is fixed and we don't have to spend $80.00 for a service call. AAELLIOTT
Old December 5th, 2008, 10:03 AM
Excellent, sounds good.
Bad Oven solenoid? gv1 GE/Hotpoint 3 September 19th, 2008 07:53 PM
kitchenaid oven - preheat and temp display problem BTraut KitchenAid 8 February 7th, 2008 06:16 PM
Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank msarbpd Frigidaire/Tappan/Electrolux 4 November 28th, 2007 11:34 AM
Whirlpool Super Capacity 465 / Gas Oven jeff_465 Whirlpool 4 November 25th, 2007 12:26 AM
