Old January 16th, 2009, 08:30 PM
shleppy is on a distinguished road
Default Residue in Whirlpool DU920PWKQ0
I own a whirlpool DU920PWKQ0 dishwasher and every time I run the dishwasher it leaves a signifigant amount milky streaks and white powdery residue on everything (all the dishes and parts on the bottom of the dishwasher). There is also a visble residue on the heating element. (see photos)
I thought that this was just deposits built up over time (the dishwasther is 4 years old) so I tried running the dishwasher 5 or 6 times, empty, with vineger, but it didnt help. I also tried using a 1/2 cup of CLR with an empty wash several times but the deposits continue. I also ran the dishwasher empty, with no soap about a dozen times to try and give all the residue a chance to cycle out of the dishwasher but that didn't help.
I also thought that perhaps my water was hard and that the hot water supply was supplying the deposits so I took off the screen of all my sink spouts in the house and all of them were clean.. no calcium deposits or residue. I have not pulled the actual water supply lead to the dishwasher to look for residue, but I doubt it would have residue when the sink 2 feet away that feeds from the same hot water supply does not.
I also read that some detergents are more prone to leaving residue so I tried 3 or 4 different brands. no change. I do have rinse aid in the dishwasher, but I think this is beyond help from rinse aid.
This residue problem slowly built up over the last 6 months, and did not exist prior. The dishwasher is heating the water appropriately, does not appear to have food clogging it (it fills and drains fine) but maybe there is something deeper in the machine I should check. It also seems to have the appropriate amount of water in it when it is running (water fills just below the float level). The float also works (moves freely). Everything seems mechanically sound but maybe I am missing something?
Ay ideas? (the pics below show the type of residue that ends up on all the dishes and the dishwasher)
Old January 16th, 2009, 08:49 PM
Yes, thats built-up pretty good.
This is the best product to get for this issue:
A great Dishwasher cleaner to get rid of hard water and mineral deposits in the dishwasher:
Citric acid- mineral deposit remover
Old January 20th, 2009, 07:30 PM
Thanks for the advice.. I'll give that magic powder a try .
Just had a thought however.... I have a water heater that is always popping as the burner turns on, which is a sign that I have a lot of build up (calcium I believe) on the bottom of the water heater. I'm wondering if this is leaving a lot of disolved solids in my water. If that is the case, the disolved solids would make it into my dishwasher and then when the dishwasher goes through many cycles, the heat would eventually evaporate a lot of the H20 leaving the solids to slowly accumulate.
This would explain why I dont' have any build up in the screens of my faucets, but I have so much build up in the dishwasher. I should of course deal with the water heater issue but i wonder if an inline filter on the dishwasher water supply would help out?
Old January 20th, 2009, 08:15 PM
No, don't put a inline filter before the dishwasher.
How old is your water heater?
Old January 31st, 2009, 03:29 PM
My water heater is about 4 1/2 years old. It has been "popping" a lot so I'm sure there is residue at the bottom which I think is residue building up.
Old January 31st, 2009, 09:18 PM
Most water heaters sold within the last 5 yrs. or so are self-cleaning, unless you have just a basic water heater with no self-cleaning feature.
Does yours say on it self-cleaning?
Old February 4th, 2009, 07:53 PM
Nope.. It does not say "Self Cleaning" on it anywhere.
Old February 4th, 2009, 10:25 PM
Ok, then its likely just a basic water heater.
Old February 5th, 2009, 08:05 AM
Earlier you indicated that putting an in-line filter in the dishwasher water line was not a good idea.. why is this something that should not be done?
Old February 5th, 2009, 09:08 AM
Because it can clog-up very often and be a nuisance.
Whirlpool Duet is a Nightmare! CheerMom Whirlpool Brands Forum 2 November 3rd, 2008 09:45 AM
Whirlpool du1148xtpqa dishwasher sensing won't work dmello1284 Whirlpool 21 August 22nd, 2007 09:49 AM
Whirlpool WED9400S Drum Light nanook Whirlpool/KitchenAid 0 July 28th, 2007 05:55 PM
Done with Whirlpool & Kenmore Beyond Lemons automan1223 Sears Kenmore Brand Forum 0 March 3rd, 2007 10:57 AM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 25th, 2006 11:22 PM
