Old February 28th, 2009, 06:58 AM
MrLarkins is on a distinguished road
Default [FIXED] Whirlpool ED25QFXHB01 not cooling no fans either
Ok, I have a Whirlpool ED25QFXHB01 and its not cooling. The fans are not running either; however, the lights work. All my food is thawing.
Earlier this week, some of the food in the refrigerator was frozen. We turned the temp down a smig and now it won't run at all, no matter what temp we turn it to.
Suggestions?
Old February 28th, 2009, 08:54 AM
So, nothing is running at all now, not even the freezer fan inside your freezer section?
Sounds like your cold control thermostat went out. You would need an ohm meter to check it for continuity, but if you don't have an ohm meter, you could jump that thermostat with an alligator clip or take the wires off of it and tape them together with electrical tape just to see if your refrigerator comes on, if it does, don't leave the wires taped up, order the cold control thermostat.
Unplug your refrigerator first before touching/taping the wires!
Here's the cold control thermostat for your model:
Manufacturer's Number: 2198202
2198202
Your cold control thermostat is #9 here:
Pull the #26 & #27 knobs off first.
#25 trim just un-snaps
Don't worry you won't break it. Get a flathead screwdriver and just pry at a corner then it all will un-snap, and the screws are in front and underneath it.
Remove the 2 #3 screws in front and 2 underneath it.
Old February 28th, 2009, 10:55 AM
thank you very much...i hot hired the red and blue together and the compressor kicked on. i'll have to go get a new thermostat.
Old February 28th, 2009, 12:09 PM
Great, good job.
Old February 28th, 2009, 02:20 PM
i took the thermostat apart and it looked like an explosion went off on the inside. black char'd plastic. I have to wait til monday until i can get the replacement though...for now, all food is in the garage in 4 coolers with ice packed on,
Old February 28th, 2009, 08:52 PM
Yes, when they go out they can really blow.
Old March 3rd, 2009, 03:46 AM
had to drive 1 hour to south little rock to midsouth appliance warehouse,
paid $78 for the part,
drove 1 hour home
took 5 minutes to install
WORKS LIKE A CHARM!
you are a genius
Old March 3rd, 2009, 09:09 AM
Whirlpool Side by side not cooling jsnead Whirlpool 10 August 22nd, 2008 09:48 PM
Whirlpool Freezer and Fridge not cooling shawnr33 Whirlpool 5 June 21st, 2008 05:07 PM
Whirlpool Side by Side not cooling Neil64 Whirlpool 9 June 19th, 2008 06:16 PM
Whirlpool Conquest Not Cooling salord Whirlpool 1 October 16th, 2007 08:58 PM
Whirlpool ED22PQXDN05 Fridge not cooling waverly Whirlpool 4 October 6th, 2007 10:30 PM
