Old March 10th, 2009, 10:19 AM
dwmcqueen is on a distinguished road
Default [FIXED] Wiring replacement motor
I have a DUL240XTPQ6 - the motor started to leak and when I disassembled it, I say the bearings were all rusted.
So I ordered a replacement Dishwasher Motor & Impeller - 8535760.
However, I forgot to notice the placement of the blue and yellow wires that are attached to the motor. Which one is placed where?
Also, any other tips on installation? It looks pretty straightforward, but want to make sure I do it right.
Old March 10th, 2009, 12:48 PM
Start reading at Page#20 here:
It will show you how to remove the pump and sump assembly, then the motor assembly.
It would have been better to get the complete motor assembly which Includes volute, shaft seal, and impeller.
8534942
Sometimes volute is hard to remove from the old motor.
Old March 10th, 2009, 12:53 PM
I managed to complete dissemble the old motor, so no problems there. I'll take a look at the instructions you referred to. I think it seems pretty straightforward, I just didn't want to get the blue and yellow wires mixed up and then bust my new motor.
Old March 10th, 2009, 06:00 PM
Oh, you mean the blue and yellow that connect to the motor capacitor on the back left side of the motor as your facing it from the front?
It doesn't matter where they go, just as long as there on it.
Old March 10th, 2009, 06:39 PM
Yep - that is what I meant. Really no instructions accounted for them....
Old March 10th, 2009, 08:02 PM
Ok, thats what I thought.
Old March 16th, 2009, 07:40 AM
It was pretty easy. I didn't even need to worry about that wiring as it was already connected in the motor I received.
Pretty simple to put the new motor in - attach it with the screws and bolts, put in the bottom (and use those plastic wedge things to give it a seal), and away we go.
Dishwasher acts like new again.
Thank you so much!
Old March 16th, 2009, 09:23 AM
[FIXED] MDBH970AWS replacement motor P/N jmlay Maytag/Magic Chef/Admiral/Jenn-Air 6 January 16th, 2009 05:17 AM
[FIXED] Washing Machine Motor Upgrade Wiring billyjoe46 GE/Hotpoint 6 October 16th, 2008 09:00 PM
motor, motor control or control board??? bosshogg Maytag/Magic Chef/Admiral/Jenn-Air 5 June 21st, 2007 11:02 AM
GU1200 Noisy Motor moliver Whirlpool 10 January 31st, 2007 09:45 AM
Detergent Door will not open! Need wiring diagram. Bob Swerski GE/Hotpoint 11 July 10th, 2006 11:12 PM
