Old May 7th, 2009, 10:46 PM
frustratedinCA is on a distinguished road
Default [FIXED] GBD307 Blank Display - Constant Beeping
I have a 2 yr old GBD307PRB01.
Last couple weeks the display has dimmed and after a power outage a couple days ago, the display fails to show anything.
Turned power off for 30min and turned back on and the oven continues to beep and beep and beep. It also engages and disengages the door lock as if it were starting a self clean cycle and then abruptly releases.
The oven still heated while pushing buttons when it first happened, but now with the constant beeping I have the circuit turned off.
Please help!!
Old May 8th, 2009, 04:19 AM
Chris Z's Avatar
Chris Z is on a distinguished road
The clock control is likely shot but the only way to know for sure is to do some electrical testing using a volt meter and the wiring diagram.
http://www.servicematters.com/docs/w...iring_main.htm
Chris Z. -- RepairGuru, www.RepairClinic.com
Appliance parts, help & more
The Following 2 Users Say Thank You to Chris Z For This Useful Post:
frustratedinCA (May 11th, 2009)
Old May 8th, 2009, 08:35 AM
Yes, I agree with Chris, I've seen this happen before on a few of my customers when I worked at Sears.
Here's the electronic clock control board assembly for your model you can order:
Manufacturer part number 8303883 is RepairClinic item number 1179710
8303883
Old May 11th, 2009, 09:32 AM
Talking Fixed!
Chris & Jake,
Thanks for your prompt responses. I was able to order the part suggested and have it here on Sat. Took 20min to install and works perfect, just in time for Mother's Day.
Thanks guys!!
Old May 11th, 2009, 09:57 AM
Excellent, good job fixing it, glad you got it on Saturday just in time for Mother's Day.
Sharp Carousel R-320D Display is blank zen Microwaves 1 April 2nd, 2008 07:54 PM
blank display pamtimfarrell Whirlpool/KitchenAid 2 January 10th, 2008 07:42 PM
Blank display on Whirlpool dual oven GBD307 sdelphy Whirlpool 5 December 30th, 2007 10:35 AM
Kenmore Elite Dryer 110.60092991 - Constant Beeping rbusch Sears Kenmore 7 October 21st, 2007 11:59 PM
Blank Display 721.80809400 pdewald@sprintpcs.com Sears Kenmore 2 August 31st, 2006 03:41 AM
