I moved into a house that has a Whirlpool ED5SHAXMQ00 side by side refrigerator with ice and water in the door and a filter that mounts from the front under the unit. Eventually I realized that the previous owners did not have a filter in there, so I bought one (4396508), but I'm having problems.
The filter goes in all the way, but when i try to turn it it seems to be stuck. I put a little force into it, enough to start galling up the plastic tabs on the filter, but it won't budge. My assumption is the filter housing (2186443) is jammed. Is this something that happens? I'm pretty sure I have the right filter. Also, I tried to take the housing off, but I'm not sure how to remove the in and out water lines. They look like they're just pressed in and I could pull or pry them out, but not being sure I didn't want to break them. Thanks in advance! |
Oh, one other note in case it matters, the water and ice in the door work fine now, they're just obviously not being filtered.
Thats odd,
Yes, thats the correct water filter for your model: Manufacturer's Number: 4396508 Did you put the #30 handle on it and push it in then turn it?: ![]() Jake
yes |
Ok, then yes, it sounds like something in the filter housing is broken then.
Here's the filter housing for your model, you can order it: Manufacturer's Number: 2186443 Jake
Hi Jake,
I have not seen a problem with one of these housing myself, but I have a feeling there is something going on with them. In just the last few weeks we have been selling a number of replacement housing. It would be great if elitheiceman could take a closer look at the old one when he gets it out and let us know what happened with it. |
ApplianceJunk,
Will do, I'll let ya know what I find out. Can either of you answer how to remove the waterlines? Do I just pry them out of the old housing? Thanks again |
Yes AJ, even back when I worked for Sears I had a few of these filter housings either leak or not be able to lock-in the filter properly.
| FRS23KR4AW2 keeps freezing my" Filter Housing "causing water leak. | zog | Frigidaire/Electrolux | 1 | June 1st, 2007 07:04 PM |
| Whirlpool ED22DWXTN00 Water Filter Question | tmgolf | Whirlpool | 3 | February 21st, 2007 10:08 PM |
| Filter Housing Leaks | jgahagan | Frigidaire/Electrolux | 9 | November 28th, 2006 09:16 PM |
| FRS26SM4A Water Leak from Filter Housing | esypes | Frigidaire/Electrolux | 5 | October 22nd, 2006 10:44 PM |
| HELP! kenmore SxS water filter housing hoses leaking | karen r. | Sears Kenmore | 1 | December 19th, 2005 07:20 PM |
