Old June 12th, 2009, 07:20 AM
aberfoyle is on a distinguished road
Default overflow
I think I have read the answer to this one several times but the water on the modular ice maker in our whirlpool s x s refrigerator overflowed to the point of dripping when the valve stayed open for several seconds too long. I have only caught it doing this once so far. It does not drip between fills so it would be the ice maker instead of the fill valve?
Old June 12th, 2009, 08:00 AM
Is this the model# of your refrigerator:
106.54582400
I read your other previous posts, and did you replace the ice maker control module 2 years ago when that gear fell off?
Usually its a bad ice maker module that causes it to overflow, but if you changed it 2 years ago, it would be odd for it to go bad again so soon.
Old June 12th, 2009, 08:09 AM
I ended up replacing the whole ice maker two years ago as the cost was about the same as a module. The ice maker I replaced was about two years old. I admit that we use the ice maker and water dispenser to the extreme. I just want to make sure the over run is due to the icemaker instead of the valve sticking open.
Old June 12th, 2009, 01:26 PM
Yes, it should be just the ice maker causing the overflow, if it was the water inlet valve, then it would either always drip water into the ice maker or just continuously run into the ice all the time, till you turned you house water supply line off.
Since you use your ice maker to the extreme, it may be to your advantage to add the Lifetime Warranty for $23.74 when you purchase it here:
http://www.pcappliancerepair.com/cgi...ate_id=AppBlog
Kenmore 106.53632300 Icemaker Overflow hughlowe Sears Kenmore 7 July 4th, 2009 09:55 PM
GE Washer Overflow Tube Problem...Tranny? CryHavok76 GE/Hotpoint 3 May 9th, 2008 11:28 AM
Amana Icemaker Overflow bossler Amana 1 June 18th, 2007 10:45 AM
S-S Icermaker Water Overflow sswity GE/Hotpoint 1 May 21st, 2006 11:32 PM
GE Washer Agitating Overflow on Super Load Ribean98 GE/Hotpoint 5 February 15th, 2006 11:29 AM
