Old July 7th, 2009, 01:06 PM
pumpkinfuel is on a distinguished road
Default Double oven won't stay on
I have a Whirlpool Double oven Accubake, Model RBD245PDQ12. When I turn either oven on, it will start to heat up for five or ten minutes then stop and the control panel shows the following codes: E6 and F2.
Help!
Brad
Old July 7th, 2009, 05:54 PM
Hi Brad,
When it does that:
Press CANCEL. If error code returns after 60 seconds, replace keypad.
Let me know what happens.
Here's the keypad assembly for your model, in case you need to order it:
Manufacturer part number 8300428 is RepairClinic item number 904489
8300428
Old August 13th, 2009, 02:45 PM
Default Not fixed yet
Replacing the panel did not change anything. Anymore ideas?
Old August 13th, 2009, 04:53 PM
Its ok, if the control panel didn't fix it, you can return it for a full refund and order the clock assembly here:
Part#8302967
whirlpool double wall oven doesn't work Barreras Whirlpool 7 October 9th, 2008 08:19 AM
Kitchenaid kebs208dss10 double oven trouble Ann Foust KitchenAid 1 April 5th, 2007 09:20 AM
jkp56 Double Oven Heating Issue wildhorsesfilm GE/Hotpoint 5 January 3rd, 2007 08:58 AM
