Old August 5th, 2009, 05:59 PM
cyberwatson is on a distinguished road
Default GU980SCGQ0 dead
We have a 10 year old Quiet Partner Gold that has always worked perfectly. 2 days ago, it just stopped working. The touch pad doesn't light up when you push it. Nothing happens at all. I've read the threads about similar problems & tested the solutions, but am still stumped.
I'm not much of an electrician, so I'm not sure I've done everything right.
The thermal fuse does have continuity.
The door switches appear to work although one switch does show about 20 volts when the circuit is open. Please see attached image for clarification.
I don't know where to go from here. Please let me know your thoughts.
Old August 5th, 2009, 09:35 PM
You can ohm the door switches for continuity with the wires off. Turn your breaker off first to. When the door switch buttons pushed in you should have continuity.
Also check below you tub where your main power comes into it, you should have a access panel below your door, then the main power comes into it from the metal junction box in front. I've seen the wires nuts either come loose or burn off.
If those check good, then its possibly your control board.
Manufacturer's Number: 8051136
8051136
But at $140 for it and your dishwasher already 10 years old, maybe better to invest in a new dishwasher, as other parts as wearing as well.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/whirlpool/16220-gu980scgq0-dead.html
Posted By For Type Date
Whirlpool on Appliance Blog Forums | BoardReader This thread Refback August 29th, 2009 09:25 AM
Keypad Dead hornbrod GE/Hotpoint 9 July 24th, 2009 12:05 PM
Admiral washer,mdl#AAV2200AJW DEAD delroy Maytag/Magic Chef/Admiral/Jenn-Air 0 July 4th, 2009 04:45 AM
Maytag Washer Dead Model#MAH5500BWW mgrocks Maytag/Magic Chef/Admiral/Jenn-Air 1 May 28th, 2009 05:34 PM
GE Profile Dishwasher Dead - Need Help dansk GE/Hotpoint 1 July 23rd, 2007 07:58 PM
Whirlpool Dryer Model: LEQ9508KQ0 is dead JCNiest5 Whirlpool/KitchenAid 7 August 27th, 2006 10:40 AM
