My Whirlpool double oven model # RBD275PDS15 would not turn on and display was blank. The keys would beep and oven light would work, but display was blank. After several days the error code E6 F2 appeared on display. The oven will turn on and the clock will display when the clock button is pressed. Start ? will appear under the time.
What is wrong with the oven controls? Will the display quit working again? What test can I run myself to check things out? Thanks, Mike |
Hi Mike,
F2 E6 says this: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 sec., replace keypad. 3. Replace control. Here's the keypad control panel assembly for your model: Manufacturer part number 8300429 is RepairClinic item number 831536 8300429Here's the control board for your model: Manufacturer part#8302319 is RepairClinic item#1027942 ![]() To access inside your control panel open your oven door then take off the side trim#2 here on each side: http://c.searspartsdirect.com/lis_pn...5120-00001.png I believe it just has one screw on each side holding in the trim, then once the trim is off you will see 2 screws on each side of the bottom of your control panel. You may need to pull your oven out from the wall a little if you don't have enough clearance at the top of your control panel to remove it. Make sure you turn the breaker off to your oven first. ![]() Jake
LinkBack to this Thread: http://www.applianceblog.com/mainforums/whirlpool/16634-whirlpool-double-oven-shows-error-code-e6-f2.html
| Whirlpool on Appliance Blog Forums | BoardReader | This thread | Refback | October 3rd, 2009 11:41 AM | |
| [FIXED] Whirlpool double oven no display rbd305pds15 | rjheard | Whirlpool | 13 | September 5th, 2009 09:45 AM |
| whirlpool double wall oven doesn't work | Barreras | Whirlpool | 7 | October 9th, 2008 08:19 AM |
| Whirlpool RBD305PRB Double Wall Oven Display Dim | mangowhirlpooltango | Whirlpool | 1 | March 10th, 2008 10:04 PM |
| Whirlpool double oven not working | Canes-Fan | Whirlpool | 1 | March 20th, 2007 11:26 PM |
| Error codes on built-in double oven model # RBD306PDQ14 | spthomas | Whirlpool | 10 | September 19th, 2006 12:05 AM |
