  #11
Old November 4th, 2009, 05:07 PM
Jorge Mario is on a distinguished road
Default the never ending story.....
quick question: it looks like when the frezer goes to the short warm cycle all the water is falling into the refrigerator. I don't think that is right. Did I set up something wrong when I change the evaporation motor?
Again, thanks a lot for your help,
Sincerely,
Jorge
Old November 4th, 2009, 09:01 PM
I'd check your ice maker fill tube where the water comes into your ice maker, that may not be set-in properly.
Old November 5th, 2009, 03:00 AM
Hi Jake,
Well the water was leaking from the freezer into the fridge even with the water line shut off. That was the reason that I thought it was during the defrost time.
Thanks again for all,
Old November 5th, 2009, 08:21 AM
Did you check your defrost drain hole for ice blockage? Its located under the evaporator coils behind the back panel in the freezer.
Use a hair dryer/hot water to defrost it.
Then run something down the drain hole.
[FIXED] Kenmore Not Cooling - 106.44102300 adam12 Sears Kenmore 3 June 29th, 2009 10:28 PM
intermittent cooling R Jones Whirlpool 5 February 24th, 2008 11:05 AM
Maytag fridge not cooling MSD2356AEW richard tomasetti Maytag/Magic Chef/Admiral/Jenn-Air 17 June 12th, 2007 12:18 PM
253 not adequately cooling Gene Sears Kenmore 5 February 15th, 2007 06:55 PM
refrigerator not cooling gina Refrigerators & Freezers 6 March 3rd, 2005 11:36 AM
