My 1996 Whirlpool uprighht freezer drain continually ices up, I have thawed it several times but it always comes back. I put bleach down the drain once a month and the last time I thwed her out I tried to run a thin wire down the drain but it only goes in about one inch. Drain is located inside the freezer and at back of freezer cabinet in a "V" shp drain cavity. Is there a check valve or trap that prohibits me from rodding this drain out? If so how can I clear it?
Bubba |
Hi Bubba,
I always like to use 1/4" plastic water line tubing to run down that drain line, you can buy that at any hardware store, you can always ask them for a small metal drain router that will snake down it as well. Jake
Thanks, I will try that. I have some flexible plastic drain tubing in my garage and if that does not work, the small snake sounds good.
Sounds good Bubba,
Good Luck, Jake
My mom's Whirlpool upright freezer recently developed the same problem. We tried pouring clorox down the drain and it flows down into the drain pan after the freezer has thawed, but the drain is clogged again about a week later. We have repeated 2 or 3 times. Did the plastic tubing solve the problem?
| Whirlpool GU1200XTKB0 won't drain, but works ok otherwise | RockwallMike | Whirlpool | 5 | October 24th, 2006 08:59 PM |
| Kenmore 253.9260211 Upright Freezer... Soft Serve Anyone? ;-) | jeaton | Sears Kenmore | 9 | May 6th, 2006 07:22 PM |
| Locating Freezer Drain | CWB | Frigidaire/Electrolux | 12 | February 5th, 2006 11:17 PM |
| Whirlpool Upright Freezer Failure | tester41 | Refrigerators & Freezers | 3 | October 15th, 2005 10:04 PM |
| Another Whirlpool Dishwasher won't drain | rickm | Whirlpool | 1 | August 8th, 2005 10:11 PM |
