Old January 18th, 2006, 06:51 AM
grog is on a distinguished road
Default Whirlpool Range Oven Door Won't Stay Closed
Whirlpool CleanTop Model# SF317PEYWL. Door won't stay closed (remains open approx 1") and also will not stay at the "stop" position midway between closed and open. I took the door off, sprayed the hinges with wd-40 and visually checked the hinges, but can't see anything wrong with them. I did not remove the hinges because I wasn't sure if I would have the proper tools to remove and re-attach the spring. This happened once before and while I was looking at the problem, I just pushed down on the top of the door, felt something "pop" a little, then it was fixed. This time, that's not working. If anyone has any suggestions, I would greatly appreciate it.
Old January 18th, 2006, 08:01 AM
Sounds like the hinges need to be replaced, they have worn out at the stop. Might want to replace the springs too if it will not stay closed all of the way, but take a look at them first.
whirlpool double wall oven doesn't work Barreras Whirlpool 7 October 9th, 2008 08:19 AM
Whirlpool SF395LEEQ 0 - Oven not lighting (photo) newdy22 Whirlpool 12 April 29th, 2008 11:33 PM
Whirlpool range oven light not working ysp Whirlpool 1 January 30th, 2007 09:15 AM
Oven Not Working - Whirlpool Range Model # SF3020EGW kihtap Whirlpool 3 October 23rd, 2006 09:30 PM
Whirlpool range SF369LEKT oven intermittent tmurphy Whirlpool 4 July 31st, 2006 09:01 AM
