Results 1 to 2 of 2
Thread: Door leaks
    CodePoet is offline Member
    Jun 2012
    Michigan
    Default Door leaks
    Model Number: DU940QWDB6
    The door is leaking above the kick plate about 3 inches from the left side. I replaced the door gasket a week ago when the leak was first noticed, but now the leak has returned.
    Thanks for your ideas.
    Check the ring seal #13 here:
    http://c.searspartsdirect.com/lis_pn...7023-00004.png
    thats either out of place or just worn out enough to leak.
    Here's the ring seal for your model you can order here:
    Manufacturer part number 302711 is RepairClinic item number 480677
    302711
  1. Dishwasher door leaks from bottom right, changed door gasket and water deflectors
    By hardknox00001 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 28th, 2012, 12:15 PM
  2. Dishwasher Leaks From Bottom Of Door
    By Konner in forum KitchenAid
    Last Post: January 22nd, 2012, 01:29 PM
  3. Ice dispenser leaks outside freezer door.
    By dschmidt in forum Sears Kenmore
    Last Post: July 11th, 2010, 03:48 PM
  4. Ice maker won't work, door leaks
    By Bcarroll7 in forum Sears Kenmore
    Last Post: June 28th, 2010, 12:48 AM
  5. KUDS25SH door leaks at startup
    By thechief in forum KitchenAid
    Last Post: February 20th, 2007, 11:50 PM
