June 25th, 2012, 05:17 AM
whirlpool quiet wash plus won't start cycle
Dead Whirlpool dishwasher:
The lights on the panel work, and they do respond to button inputs to change cycles....but the unit will never turn on. I do hear a slight click internally after I hit hit the start button, but beyond that the dishwasher does nothing. Does not fill with water, does not hum, nothing. Cancel/drain button works fine. I did check the thermal fuse, and that appears to be OK. ( I disconnected the fuse, and the front panel doesn't work at all. I didn't ohm out the fuse.)
Thanks for any input.
June 25th, 2012, 10:11 AM
Then the problem is your control board.
Here's the control board for your model you can order here:
WHIRLPOOL 8531292 Control Board, AP3133674 | AppliancePartsPros.com
By Grover in forum Whirlpool
Last Post: January 30th, 2011, 05:12 PM
By JamesAndRebecca in forum Whirlpool
Last Post: January 14th, 2011, 11:21 PM
By jeo in forum Whirlpool
Last Post: November 18th, 2010, 11:58 AM
By Goldstone in forum Whirlpool
Last Post: September 12th, 2010, 07:48 PM
By BitterEpiphany in forum Whirlpool
Last Post: October 14th, 2006, 12:29 AM
