Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Whirlpool Quiet Partner III GU1200XTKQ0
  1. #11
    snsumner is offline Member
    Oct 2005
    Brentwood, CA
    Question How to access motor?
    I too am hitting the exact same problem where when my motor starts it makes a loud grinding noise. So I have to assume my motor is not working properly and needs to be replaced.
    But, how do you get access to the motor? Can you replace it from within the dishwasher or do you have to physically move the unit and flip it on side to access the motor from the bottom?
    Also somebody mentioned they found a motor cheap on Ebay I don't see any listed there. Is there another place I can purchase the motor for cheap?
    Any help is greatly appreicated.
  2. #12
    If you have checked the chopper in the previous posts, and its all clear, you should be able to move that chopper blade around, if you can't then its likely a motor/pump bearing issue, its best to change it as a complete assembly.
    I wouldn't recommend buying it on ebay, all you do is go here www.applianceblog.com/parts then enter your model# in both of the 2 appliance parts companies that are listed, and compare prices and return policies.
    Fernando is offline Member
    Sep 2006
    California
    Thumbs up Whirlpool Dishwasher model GU1200XTKQ0
    Wow! That sounds like the same problem I am having. I just took apart my dishwasher, although I thought it was fairly new since I just bought the house 1 year ago and the previous owners put in new appliances. Well my dishwasher made the same loud noise then it stopped working, only making a buzzing sound like the motor was stuck. When I pulled the impeller off I noticed lots of water corrosion and the bearings looked bad. I tried the dishwasher with the motor off and noticed that it turned but then got stuck. The problem appeared to be worn out bearings and a leaking impeller. I am going to find the bearings and impeller and see if that will to the job.
  4. #14
    Quote Originally Posted by Fernando
    Yes, I doubt you would be able to find the motor bearings anywhere, unless you have a bearing shop in your area.
    Here is the complete Motor & Impeller assembly for your model:
    Circulation motor and impeller assembly
    GH1963 is offline Member
    Dec 2010
    USA
    Default I'm having the same problem
    Took the dishwasher apart and cleaned the food grinder but still having the same problem. I'm ready to replace the circulation motor....but my question is: do you access it from inside the tub of from the back/bottom of the dishwasher?
    Hopefully someone can answer this.
  6. #16
    We need the model# of your dishwasher first.
    Help Me Find My Model Number - RepairClinic.com
    Mmfh is offline Member
    Apr 2009
    Portland, Oregon
    This issue may have been taken care of but I thought I would add that I had the exact problem with my quiet partner 3. Very noisy and the Chopper was getting torn up but not because of stuff in the chopper area.
    The bearings on the motor were so bad that the chopper was moving around and the blades were hitting the side of its housing and chewing everything up as it spun.
    I found a dishwasher just about like mine on Craigslist and offered him $35 for it and he said OK. I removed the motor from the new to me dishwasher, (from the Bottom) and after removing my washer from the cabinet switched the motors and now it works again like it did when I bought it new.
    That's my story, maybe it will help someone.
    Mm
  8. #18
    Thanks Mn for sharing what you did to help others.
    Dec 2010
    Missouri
    Default I had the same problem
    Yesterday our Whirlpool Quiet Parnter II started making a grinding sound when operating just like described in the other posts. I talked to a guy at a local repair store and he said I'd have to bring it in to have it checked out.
    I read your recommendations about checking the grinder to see if there was something there. I took it apart this afternoon and found a small piece of hard plastic - it looks like it was broken off one of the basket wheel axles. I took it out and the noise was gone.
    Thanks for the advice and the instructions. It saved me a ton of time and was much easier than trying to take the whole thing out of the cabinet or replace the motor.
    John
  10. #20
    Good job John.
  1. How do I remove the food grater from a Whirlpool Quiet Partner III?
    By craniac@gmail.com in forum Whirlpool Reviews
    Last Post: May 24th, 2007, 05:56 PM
  2. Whirlpool Quiet Partner II floor drying
    By srmulvihill in forum Whirlpool
    Last Post: April 18th, 2007, 02:43 PM
  3. Quiet Partner III - how do you slide it out?
    By Willie in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 17th, 2007, 02:26 PM
  4. Replies: 0
    Last Post: January 16th, 2007, 08:57 AM
  5. Whirlpool Quiet Partner III Dishwasher Skipping Wash Cycle
    By BitterEpiphany in forum Whirlpool
    Last Post: October 14th, 2006, 12:29 AM
