Old July 20th, 2006, 06:46 AM
lily99 is on a distinguished road
Default GB8SHK - ice on bottom of freezer and unit is leaking water from front
Hi there,
My GB8SHK Whirlpool fridge/freezer is leaking water on to my floor in front of the unit. As well, I have noticed that an ice sheet has built up on the bottom of the freezer.
I have researched this problem and it looks like the defrost drain system is plugged.
Can anyone walk me through how to troubleshoot and hopefully fix this issue with my kind of fridge?
Thanks in advance!
Old July 20th, 2006, 10:51 PM
jmshaffer is on a distinguished road
remove food from freezer, take shelves out. Take back panel of freezer (lower panel) off. Chip ice out and pour water in area until clog releases. A shop vac (wet vac/ or lots of towels) will come in handy. Usually takes me 15 minutes, but give yourself an hour. I then personally take a piece of heavy gauge bare aluminum wire and hang it off the heater and about an inch into drain hole. This helps keep hole thawed during defrost. Wrap around heater a few passes. I do this as an old trick, and it works, but be very careful around that evaporator. It'll cut you fast. Please unplug first! The water freezing and ice is a result of defrost water freezing up instead of going down. After clog out, pour a 10:1 solution hot water to liquid dishsoap down drain. The dishsoap also aids in keeping things from freezing, although just slightly. There may be other techniques, but this is what I do and it's successful.
GE Monogram side by side leaking at bottom right of door? LosGatos GE/Hotpoint 4 May 28th, 2008 09:53 PM
Location of Adaptive Defrost Unit in Amana Bottom Freezer aclem36 Amana 3 February 24th, 2007 06:15 AM
Ice under drawer of our Amana bottom freezer model BL20KW Krinkrose Amana 1 September 20th, 2006 01:53 AM
GE Performance Profile freezer leaking and frosting at ice maker outlet bbwlp GE/Hotpoint 3 September 22nd, 2005 08:09 AM
Amana bottom freezer unit. Freezer cold, refrigerator warm billgould1 Amana 12 July 15th, 2005 06:28 AM
