Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: whirlpool quiet partner ii - no power
  1. #21
    e92miami is offline Member
    Jan 2011
    Miami Beach
    Ok, then if the Sani-Rinse is flashing, that means a bad control panel.
    You will need a torx screwdriver, I believe its either T-15 or T-20.
    Manufacturer part number 3385741 is RepairClinic item number 1059017
    Here's the video to change it:
    I mentioned the sani rinse light blinking was the original problem, this was posted after I already purchased the control board.
  2. #22
    Where did you buy the control board at? If you purchased through our site you can return any electrical part for full refund.
    Swim and Ski is offline Member
    Mar 2011
    Colorado
    Default Replaced thermal fuse, but it died again
    So I took Jake's advice and replaced the thermal fuse, though I didn't replace the wires. Within a month, that fuse died again. I'm assuming I have an issue elsewhere, but I'm not sure how to diagnose it. Should I try to replace the fuse and wires again? Or is my issue a bigger problem?
    Thanks for your help.
  4. #24
    Thats the problem, you MUST change the wires that come with the new thermal fuse, or it will keep going out forever.
  1. Replies: 3
    Last Post: May 24th, 2007, 11:38 PM
  2. Whirlpool Quiet Partner II floor drying
    By srmulvihill in forum Whirlpool
    Last Post: April 18th, 2007, 02:43 PM
  3. Replies: 0
    Last Post: January 16th, 2007, 08:57 AM
  4. Whirlpool Quiet Partner IV - Stops in mid wash
    By nbowen in forum Whirlpool
    Last Post: October 19th, 2006, 08:50 PM
  5. Whirlpool Quiet Partner DU960PWKQ0 not draining
    By nightDenizen in forum Whirlpool
    Last Post: September 22nd, 2005, 09:31 PM
