The top rack of my Whirlpool Quiet Partner II does not have enough clearance for wine glasses (stemware). It does not appear to be adjustable - but I'm hopping there is someway to make it adjustable. I can unclip the plastic connectors and the rack seems to slide down an inch or two on its own - but then I cannot reclip at the lower height. Is there someway to do this? Any help would be appreciated.
Alternatively I see in the "Use and Care Guide" that some other models which are similar to the DUL200 series do indeed have adjustable connections which support the rack. I think these clip-on devices are called "Retainer, flexrow". Does anyone know if it is possible to order these adjustable fittings which are intended for one of the other Whirlpool dishwashers and install them on my DUL200PKQ1 ?
These are the models covered by the whirlpool use and care guide:
DU620, DU943, DU950, DU951, DU960, DUL200
http://www.whirlpool.com/custserv/li...erm=DUL200PKQ1
