Old January 24th, 2007, 12:14 PM
truesdaleg is on a distinguished road
Default GS5SHAXNB00 ice maker problem
MY two year old Whirlpool side-by-side stopped making ice. I removed the ice maker thinking I might just replace the whole unit. I closed the door switch, cleared infrared path and measured the voltage between the two middle pins on the cable. It measured about 58 volts. Shouldn't it be 110 volts? Is there something else that should be checked before I concluded the problem is in the Ice maker unit?
George
Old January 25th, 2007, 12:43 AM
Yes, it should be 110-120 volts.
Read over this thread, it has an online repair manual in it that should help you test it further:
[FIXED] Kenmore & Whirlpool Ice Maker LED Blinking Codes & Online I/M In-Door Repair Manual
Old January 25th, 2007, 11:13 AM
I read this and all related threads, but I didn't see any reference to low voltage. I did check out the blinking light, and it seems to be working properly. I couldn't do the T-H jumper test because I didn't see how to do it. What are the functions of each of the four wires going to the ice maker.
Thanks for your help.
Old January 25th, 2007, 11:40 AM
Jake, disregard the last message. I found the information on how to perform more tests. I will get back to you later.
Old January 25th, 2007, 11:58 AM
Ok, sounds good.
Old January 25th, 2007, 04:34 PM
I tried jumpering T & H and the motor did not run. I measured the voltage between N & L and got about 58 volts. Now what?
Old January 25th, 2007, 10:51 PM
Ok, then that means you will need new sensor boards.
Here are the boards you can order, they come together in 1 kit with instructions:
P.C. Board kit, emitter & receiver
Old January 25th, 2007, 11:41 PM
I've ordered a new set of boards from RepairClinic.com. I'll let you know how they work out. Thanks for your help.
I'm curious how these boards can effect the supply voltage to the ice maker unit. The power carrying wires to the Ice maker look considerably larger than any of the wires to the sensor boards, so it doesn't look like the power could be routed through the boards. Do these boards control something else, that is in the power path, that could be dropping the voltage? Is this something you can explain to a novice like me?
George
Old January 25th, 2007, 11:57 PM
I may have answered my own question. I made a typical novice mistake and only looked at part of the picture. I had only looked at the left sensor board and it only had small pins on the connector. The right sensor board has wires as large as the power wires going to the ice maker unit, so the power is probably routed through that board which could be causing the voltage drop.
George
Old January 26th, 2007, 01:10 AM
Did you measure the voltage with the ice maker unplugged from that connector your ice maker plugs into? If you are getting 120 volts at that plug without the ice maker plugged into it and you only read 58 volts with the ice maker plugged in, then chances are that module is bad, not the boards, but from your first post I thought you tested it with the ice maker unplugged and only got 58 volts like that.
Did I miss understand you? Its ok anyways, if the new boards don't fix it, you just return them for a full refund and order the Ice Maker Module here:
Icemaker control module kit
Thats why I like referring people to Repair Clinic, you can return any part within 30 days if it doesn't fix it.
Whirpool Conqest Gold Side by Side Ice Maker Problem tadpole88 Whirlpool 13 September 21st, 2007 12:29 PM
Ice Maker problem???? MNKam KitchenAid 4 May 9th, 2007 01:06 PM
another Ice Maker problem KC73 Sears Kenmore 1 September 14th, 2006 12:54 AM
Whirlpool ED22DQ/RQ Ice Maker problem Rich46 Whirlpool 5 September 11th, 2005 10:16 PM
Jenn-Air Ice Maker Problem mhc Maytag/Magic Chef/Admiral/Jenn-Air 1 June 16th, 2005 12:22 AM
