Old February 5th, 2007, 06:30 PM
magna8385 is on a distinguished road
Default Whirlpool super capacity 465 gas oven not lighting
Hello,
I have a whirlpool super capacity 465 gas range model number sf357beh. It is at least 5 to 7 years old. The oven occasionally will not light. The digital display indicates that everything is working, but no gas and no spark. Sometimes it works, heats up to temperature and will not keep working to keep the temperature up. This is a random event that seems to get less random as time goes by. This problem is with bake and broil. The stove top generally works, but occasionally the gas will work with no spark, or neither gas or spark will work. This always happens when the oven is not working, but 95% of the time the stovetop will work when the oven does not. Never has the stovetop had problems when the oven has not. From reading other similar problems, I would assume that the control panel is bad. If so, are any available. If not what could it be. Please Help. Thanks.
Old February 5th, 2007, 09:04 PM
flexjay is on a distinguished road
i would ckeck the amp draw on the bake ignitor. it's probably weak. or you could roll the dice and replace it . if you have to buy amp probe and ignitor, might just as well call a pro, both options are expensive, depends on how fast you want it fixed. i would not buy a control unless you know it's bad.
Old February 6th, 2007, 05:36 PM
There another letter and number after 'h' at the end of your model#. Like this:
Model NumberModel DescriptionBrand
SF357BEHGAS RANGEWHIRLPOOL
SF357BEHW0GAS RANGEWHIRLPOOL
SF357BEHW5GAS RANGEWHIRLPOOL
SF357BEHW6GAS RANGEWHIRLPOOL
SF357BEHW7GAS RANGEWHIRLPOOL
Here is a good help thread on your model, with even a couple of repair manuals you can download:
http://www.applianceblog.com/mainforums/showthread.php?t=6681
Whirlpool SF395LEEQ 0 - Oven not lighting (photo) newdy22 Whirlpool 12 April 30th, 2008 01:33 AM
WhirlPool super capacity 465 oven not working. Repair Manual JSPerdomo Whirlpool 16 January 6th, 2008 04:11 AM
Whirlpool Super Capacity 465 Gas Oven failure IanW Whirlpool 9 January 21st, 2007 10:02 AM
Electric Super Capacity 465 - Oven LED "LOC" (Oven door will open but won't heat) marcum03 Whirlpool 1 September 29th, 2006 11:41 AM
Whirlpool Super Capacity 465 Gas Oven not working whirlmamma Whirlpool 3 November 9th, 2005 07:07 PM
