Results 1 to 7 of 7
Thread: Whirlpool gu1500xtls3 poor proformance
    Mark Roban is offline Member
    Mar 2007
    minnesota
    Default Whirlpool gu1500xtls3 poor proformance
    I have had my dishwasher about 2 years and it has never really worked well. recentlly all the dishes were coming out cloudy. I tried less soap and checked water temp. It appears the water level is low as the float can be lifted to activate the microswitch. I can hear the pump running and I did the upright glass "trick" and it does fill with water. I find soap in the dispenser still and there is a build up of scum on the roof of the tub. I did find a gray seal or gasket once but i did not know where it can from. I think it might have come from the water inlet??? when running I can hear the Microswitch in the float switch on and off. Is this normal? Do you think I need a new inlet valve or water pump? any Ideas or suggestions whould be greatly appreciated.
    The water level isn't suppose to be really high, just so its under your heating element. The float seems fine, thats normal.
    The main issue we have had with these are the pump/motor assemblies and the chopper screen/check valve flapper.
    Here is 2 links that explain about it:
    [FIXED] Kenmore Dishwasher goes to next cycle before water full
    [FIXED] Default 665 Chopper Assembly - Update #2
    Mar 2007
    minnesota
    Thank you. I will let you know what I find
    Mark
    Ok, sounds good Mark.
    JenniO is offline Member
    Mar 2007
    IOWA
    Do you have a lot of lime in your water. I had low flow once when my lines got clogged up had to replace lines and use a softener.
    Mar 2007
    minnesota
    I found the intake to the pump plugged with garbage and the water softener was unplugged! Thanks for all your help the dishwasher is working better than my kids!!
    Sounds good Mark, glad its back to normal again.
  1. Whirlpool Duet is a Nightmare!
    By CheerMom in forum Whirlpool Reviews
    Last Post: October 18th, 2010, 09:54 AM
  2. Whirlpool du1148xtpqa dishwasher sensing won't work
    By dmello1284 in forum Whirlpool
    Last Post: August 22nd, 2007, 09:49 AM
  3. Done with Whirlpool & Kenmore Beyond Lemons
    By automan1223 in forum Sears Kenmore Reviews
    Last Post: March 3rd, 2007, 10:57 AM
  4. Kitchenaid vs Whirlpool?
    By rv8 in forum KitchenAid
    Last Post: January 25th, 2006, 11:22 PM
  5. Whirlpool GU1500XTLS3
    By steve t in forum Whirlpool
    Last Post: December 18th, 2005, 10:51 PM
