May 24th, 2007, 05:17 PM
Whirlpool Quiet Partner II Dishwasher Not Draining Water Out
Need help with my Whirlpool Quiet Partner II...it has stopped draining the water out at the end of the cycle. I have taken it apart and cleaned the drain out. Does it need a new pump to pump the water out?
May 24th, 2007, 09:27 PM
Hi cheryldaniels,
Could I have your model # open the door , it should be around that area. Look near the top.
Rick
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
May 24th, 2007, 10:03 PM
Whirlpool Quiet Partner II Not Draining
Rick, Thank you for replying so fast. Here's the model number:
DU 1145 XTPQ 3
When the dishwasher finishes there is water at the bottom of it and the dishes all have Cascade soap stuck all over them.
I am fixing to call a repairman and they are expensive.
Cheryl
May 24th, 2007, 11:38 PM
Hi cheryl,
I think the drain pump has failed. First, check your drain hose to see if it's blocked. If the drain hose is connected to a food disposer, check that end first. The drain pump (part# 661658) is about $45
Rick
By oneder in forum Whirlpool
Last Post: January 16th, 2007, 08:57 AM
By nbowen in forum Whirlpool
Last Post: October 19th, 2006, 08:50 PM
By BitterEpiphany in forum Whirlpool
Last Post: October 14th, 2006, 12:29 AM
By mamadukes in forum Whirlpool
Last Post: October 26th, 2005, 08:36 AM
By nightDenizen in forum Whirlpool
Last Post: September 22nd, 2005, 09:31 PM
