Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: LG Window A/C Compressor does not turn off
    wiltel10 is offline Premium Member
    May 2011
    Texas
    Default LG Window A/C Compressor does not turn off
    Model Number: lw1510er
    Brand: LG
    I have a LG lw1510er and yesterday I turned the unit off and the compressor stayed on. I have checked the function on the display and I can change the fan speed, change the timer, modes and adjust the temperature but the temperature never physically changes it is always cold since the compressor stays on all the time. Nothing has been changed I cleaned the unit last summer and haven't has any trouble with it till yesterday. What could the problem be is there a relay that is failing or the board and are these parts serviceable? I have used this forum before and the help was right on and was able to fix my fridge with ease. I appreciate any help that is given.
    Oct 2004
    Yes it does sound like a relay for the compressor is stuck/welded closed all of the time = new board time...
Size:  4.1 KB Pcb assembly/relay board, main Manufacturer Number EBR39283901
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    May 2011
    Texas
    Thanks Jeff,
    Going to order it right now and will post results when I get it installed.
    Oct 2004
    Please do let us know how the repair goes.
    JRAppliance
    May 2011
    Texas
    Part came in today installed during lunch took me about 15 minutes and now the A/C is working perfect again. Thanks for your help Jeff I really appreciate it. I would also like to say this is a great forum with many knowledgeable people willing to take the time and help.
    Thanks again Jeff
    Oct 2004
    Thankx for the update
    JRAppliance
    beachn is offline Member
    Jul 2012
    Florida
    Quote Originally Posted by jeff1 View Post
    is this the correct part? when I go to the website and look for parts, it doesn't show that particular part. I have the same model LW1510ER thank you
    Jul 2012
    Florida
    I should also state that when I turn it off and the compressor stays on, the only way for me to completely turn it off is either to unplug it or hit the test reset button on the cord to turn it off completely.
    Oct 2004
    LW1510ER
    I got....
Size:  4.1 KB Pcb assembly,main Manufacturer Number EBR39283901
    Above is what you need.
    JRAppliance
    Jul 2012
    Florida
    thank you, just ordered from your link.
  1. window a/c displays 'EE'
    By pdolce in forum Window & Room Air Conditioners
    Last Post: July 20th, 2011, 03:38 AM
  2. Replies: 28
    Last Post: September 26th, 2009, 08:50 AM
  3. Sears Kenmore Elite compressor won't turn on
    By J&T in forum Sears Kenmore
    Last Post: May 26th, 2009, 07:47 PM
  4. window unit help
    By jessie jo in forum Window & Room Air Conditioners
    Last Post: May 30th, 2008, 05:31 PM
  5. Samsung window unit compressor wont stay running
    By dmkolb in forum Window & Room Air Conditioners
    Last Post: June 29th, 2006, 04:24 AM
