Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > HVAC > Window & Room Air Conditioners
Window & Room Air Conditioners Have a problem with your Window or Wall A/C?
Old August 9th, 2005, 11:41 AM
dmiller12 is on a distinguished road
Default Fan turning slowly but freely?!? Help!
COOVERT (Whirlpool) Model CVACM062XLO room air conditioner. 5000 BTU.
Came home yesterday with the fan spinning extremely slowly. I thought the motor was stiff and starting to seize and proceeded to shut it off. I could see the fan slowly spin to a stop. It was not binding at all! It's as if the fan motor wasn't getting enough voltage to spin at the right speed. I can spin the fan freely with my finger with absolutely NO binding at all. Compressor appears to be working fine. Any ideas? I like this little unit and would hate to have to trash it because of something that is possibly simple to fix.
Kind regards!
Old August 9th, 2005, 12:14 PM
Model CVACM062XLO
Closest that would work for me ( online ) was CVAC062XL0
Check the run capacitor, if shorted this can do that to the fan motor.
Capacitor
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old August 9th, 2005, 12:43 PM
Would this effect the fan and not the compressor? Just wondering. I wasn't sure if they used a capacitor on the fan only. Thanks!
Old August 10th, 2005, 06:00 AM
It can yes....they ( compressor and fan motor ) share a capacitor which is 2 caps builts into one body.
JRAppliance
Condenser Fan Direction thornyschizoid Refrigerators & Freezers 1 April 27th, 2008 02:46 PM
MTF2156GEW - Evap Motor Fan bad - twice in two years MadSalad Maytag/Magic Chef/Admiral/Jenn-Air 10 November 17th, 2007 01:57 PM
Kenmore Coldspot Condenser Fan? Bambachic Sears Kenmore 7 July 17th, 2007 09:57 AM
Kenmore Trio 596.76519500 low evaporator fan cfg Sears Kenmore 3 February 10th, 2007 11:27 AM
Frigidaire drum not turning freely sdunc2003 Frigidaire/Electrolux 5 May 31st, 2005 02:19 PM
