Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > HVAC > Window & Room Air Conditioners
Window & Room Air Conditioners Have a problem with your Window or Wall A/C?
Old August 12th, 2005, 09:20 PM
thermistor is on a distinguished road
Cool Bypassing a burnt thermistor
Hello. This morning the fedder ac in the wall sounded like it was under a strain and i smelled a burnt electric type smell. I took it out and tore it all apart and found that a piece was burnt. i have been on the net all day researching and have learned alot about thermistors and capacitors although i couldnt find the info i was looking for. I took the thermistor out all together and finally got the thing working about midnight. i have the thermostat on high cool so it doesnt have to kick on and off so much. I just want to know if removing the thermistor will enable another part of the air conditioner to get to much voltage and fry or will it be ok till i get a new thermistor? Thanks much
Old August 12th, 2005, 11:00 PM
If you could post the model# of the A/C that would help us.
If you are referring to the de-icing thermostat that mounts on the evaporator coil, no it shouldn't hurt, but if its the main thermostat that controls the room temperature, then i would be very careful doing that, just keep your eye on it, and don't leave your home with it running like that, till you replace it with a new one.
heater element smelled burnt k2skibum Maytag/Magic Chef/Admiral/Jenn-Air 4 March 8th, 2007 10:13 PM
GE Dryer Thermistor badonkadonk GE/Hotpoint 4 November 8th, 2006 07:56 PM
Burnt Wires at Heating Element Dayday Frigidaire/Electrolux 3 October 12th, 2006 10:15 PM
Flooding and thermistor problems? jstalnaker Sears Kenmore 4 June 26th, 2006 09:33 PM
All gas appliances have a 'burnt' smell shagberg General Appliance Chat 3 February 4th, 2006 10:13 AM
