Maintenance Tips for your Dishwasher
Maintenance Video
Interior cleaning & deodorizing
You don’t need to clean the interior of your dishwasher if you use it regularly. If it goes un-used for a week or more and begins to mold or smell bad, you can clean it using Glisten Dishwasher Cleaner and Deodorizer.
Exterior cleaning
Just clean the exterior of your dishwasher with a damp sponge and a little dish detergent.
Rust removal
Try RoVer Rust Remover to remove rust stains from the inside of your dishwasher.
Dish rack repairs
If the plastic coating wears off of the tines of the dish racks in your dishwasher, they may corrode and rust. We have repair kits available for those tines in Light Blue, Gray and White. These repair kits can be found in our Dishwasher Dishrack Parts section.
Filter cleaning
On many dishwashers, there’s a filter near the bottom, or under the lower spray arm that needs to be cleaned regularly. If you have this sort of filter, check your owner’s manual to find out how to remove and clean it. If it has holes in it, replace it to protect the pump and motor seals from particles that may be in the dishwasher.
Spray arm cleaning
Over time, the small holes in the spray arm(s) of your dishwasher may become clogged with bits of paper, toothpicks, glass, etc. Your dishwasher will do a better job of cleaning your dishes if you take a moment to clean out these small holes, from time to time.
Submit a Comment
