Sears Kenmore Washer(model#110.23034101): Washer will fill with water then stop and not do anything, also when you put it spin, nothing happens. Found the lid switch bad.
What you do to check it is to get a volt/ohm meter and put the the meter on the ohms setting, then put the meter probes in the black & red connectors from the lid switch, then push the lid switch down, if your meter reads 0-1 ohms then its good, if the meter reads nothing at all its bad.
Here’s the lid switch for this model:
Manufacturer’s Number: WP8054980
Lid Switch
Made by Whirlpool. Whirlpool brands include Whirlpool, Maytag, KitchenAid, Jenn-Air, Amana, Magic Chef, and others.
Whirlpool also makes various appliance models for Sears / Kenmore.
Part Number WP8054980 (AP3020600) is used with the following appliance models:
110.20052991, 110.20052992, 110.20052993, 110.20056993, 11020052994, 11020056991, 11020056992, 11020056994, 11020072990, 11020072991, 11020072992, 11020072993, 11020092990, 11020092991, 11020092992, 11020092993, 11020094992, 11020094993, 11020096990, 11020096991, 11020096992, 11020096993, 11020097990, 11020097991, 11020097992, 11022032100, 11022032101, 11022032102, 11022036100, 11022036101, 11022036102, 11022042100, 11022042101, 11022042102, 11022052100, 11022052101, 11022052102, 11022054100, 11022054101, 11022054102, 11022056100, 11022056101, 11022056102, 11023012100, 11023012101, 11023012102, 11023014100, 11023014101, 11023014102, 11023022100, and more.
