Archive for air conditioner
Fin Comb
Posted by: | CommentsThis tool is for straightening out the evaporator coil fins on your window or wall AC unit which is important for proper air flow through the evaporator coil.
Fin Comb Set. Most popular evaporator fin combs covering twelve different size fins on a convenient ring.
Window/Wall Air Conditioner Filter
Posted by: | CommentsNow’s a good time to clean or replace the air conditioner filter. Depending on the air quality this may need to be done monthly throughout the cooling season. This filter will fit most window or wall air conditioners.
In preparation for the cooling season, clean the condenser coils on your window or through-the-wall air conditioner. Remove the entire cover of the air conditioner to gain access to the coils. Watch out for wasp or bees nests inside the unit. The coils can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. While you have the unit open, be sure to clean any dirt or lint build up in the bottom of the air conditioner, and oil the motor if it is equipped with oil ports on the sides.
