Archive for defrost thermostat
May
19
Sears Kenmore Defrost Thermostat
Posted by: | CommentsSears Kenmore Refrigerator(Model#596.75529400): Not cooling properly. I found the evaporator, that’s located inside the freezer behind the back panel, all frosted up heavily. Before you defrost it always ohm the defrost thermostat for continuity. I did a ohm test on it for continuity with an ohm meter, found no continuity at all. Installed new defrost thermostat, worked great!
Here’s the defrost thermostat for this model:
Manufacturer’s Number: 67003426
