Archive for drain pump
Apr
27
Sears Kenmore Washer Drain Pump
Posted by: | CommentsSears Kenmore front-load washer(model#110.47532601): Making grinding sounds when the drain pump is running, found the drain pump impeller bearing bad, installed a new drain pump worked great!
Here’s the drain pump for this model, The drain pump changes from part#8540024 to part#W10130913:
Manufacturer part number W10130913 is RepairClinic item number 1373005
