GE Recalls Front Load Washers Due to Fire and Shock Hazards
WASHINGTON, D.C. – The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed. It is illegal to resell or attempt to resell a recalled consumer product.
Name of Product: GE Front-Load Washing Machines
Units: About 181,000
Manufacturer: GE Appliances & Lighting, of Louisville, Ky.
Hazard: A wire can break in the machine and make contact with a metal part on the washtub while the machine is operating, posing fire and shock hazards to consumers.
Incidents/Injuries: GE is aware of seven incidents in which flames escaped the units and caused minor smoke damage. No injuries have been reported.
Description: This recall involves GE front-load washing machines without auxiliary water heating. Model and serial numbers are listed in the chart below. Recalled washing machines were manufactured between December 2006 and February 2010. The model and serial numbers are located on the bottom right side and on the bottom door frame of the washers.
Brand Model Number Begins With: Serial Number Begins With:
GE WBVH5 AM, AR, AS, AT, DM, DR, DS, FM,
FR, FS, GM, GS, HM, HR, HS, LM,
LR, LS, MM, MR, MS, RM, RR, RS,
SM, SR, SS, TM, TR, TS, VM, VR,
VS, ZL, ZM, ZR, ZS
Sold at: Department and various retail stores nationwide from December 2006 through May 2010 for about $700.
Manufactured in: China
Remedy: Consumers should immediately stop using the recalled washers, unplug it from the electrical outlet and contact GE for a free repair. Consumers should not operate the washer until it has been repaired.
Consumer Contact: For additional information, contact GE toll-free at (888) 345-4124 between 8 a.m. and 5 p.m. ET Monday through Friday, or visit the firm’s website at www.geappliances.com
CPSC is still interested in receiving incident or injury reports that are either directly related to this product recall or involve a different hazard with the same product. Please tell us about it by visiting https://www.cpsc.gov/cgibin/incident.aspx
Sears Kenmore Front Load Washer F11 Error Code
2004 Sears Kenmore Front Load Washer Made by Whirlpool(model#110.45872400): After the wash cycle, the code F11 comes up and the door stays locked, and wont continue on. This is the 2nd one this year to do this. The problem is in the Computer Board Electronic Control(CCU), It will need to be replaced, Part#8182237. As of this date, it is on back-order. Check your warranty book on this part, it is highly expensive. It may be covered under a 2-5 yr. part only warranty.
(The manufacturer has replaced part number 8182237 with part number 8182687)
8182687 CCU
8182687 CCU
