When I go out on service calls for preventive maintance checks on washers and I noticed the rubber fills hoses that connect to the washer would get bubbles in them, some small, some large. After time those will burst and start flooding your laundry area and if your laundry room is in your house that can be quite the mess and cause massive floor damage to say the least.
So I recommend you check your washing machine fill hoses every year, and replace them if you notice bubbles. Stainless steel fill hoses are the best to get as they won’t get those bubbles in them.
6′ Stainless steel water supply hoses (set of 2 hoses)
