by Jake | Thursday, July 16, 2009 | Dryers
Frigidaire Dryer(Model#FDE648GHS0): Loud squeaking noise on every load. Found the front felt pads and rear bearing worn out.
There is a great Dryer Preventive Maintenance Kit available for these models and the Sears Kenmore dryers that start with model#417.
Dryer preventative maintenance kit 1992 – 2001
Manufacturer part number 5304461262
Dryer preventative maintenance kit 2002 and up
Manufacturer part number 5304457724
by Jake | Tuesday, April 14, 2009 | Dryers
Sears Kenmore Dryer(model#110.66832500): Dryer wasn’t turning on at all when you pressed the push-to-start switch. I used my ohm meter to check for continuity on the thermal fuse terminals, with the dryer unplugged, found no continuity. Installed new thermal fuse, worked great!
Here’s the thermal fuse for this model:
Manufacturer’s Number: 3392519
by Jake | Thursday, March 26, 2009 | Dryers
Maytag Dryer(model#PYE2300AYW): Not coming on at all, I found the thermal fuse bad by using my ohm meter to ohm it for continuity.
Here’s the Thermal fuse for this model:
Manufacturer’s Number: LA-1053
by Jake | Thursday, January 29, 2009 | Dryers
Whirlpool dryer(model#LEQ8100KQ0): The dryer runs but doesn’t heat. Found the the thermal cut-off was bad.
Here’s the thermal cut-off for this model:
Manufacturer’s Number: 279816
We talk about this in our Dryer Repair Forums:
http://www.applianceblog.com/mainforums/showthread.php?t=14133
by Jake | Tuesday, January 6, 2009 | Dryers
Maytag Dryer(model#MDE5500AYW): Not drying properly, found the control board malfunctioning.
Here’s the control board for this model:
Manufacturer’s Number: 33003028
by Jake | Thursday, December 18, 2008 | Dryers, Maytag - Admiral - Magic Chef - Jenn Air
Maytag Dryer(model#LDE5004ACW): Making a loud rumbling sound when it starts and stops and at times when its running. Found the blower wheel had worn out.
Here’s the blower wheel for this model:
Blower Wheel Y303836
