Maytag Dryer Blower Wheel
Maytag Dryer(model#LDE5004ACW): Making a loud rumbling sound when it starts and stops and at times when its running. Found the blower wheel had worn out.
Here’s the blower wheel for this model:
Blower Wheel Y303836
Sears Kenmore Dryer(model#110.66822690): Not turning on when you press the push-to-start button. Found the thermal fuse bad. I did an ohm test on it for continuity, no continuity found.
The main reason this part goes bad is vent restrictions either outside the house where the dryer vent exhausts, or behind the dryer were the exhaust hose/pipe goes into the vent, and even the vent itself can clog with lint, or I’ve seen birds build their nest in there, especially during the cooler months of the year.
Here’s the thermal fuse for this model:
Manufacturer’s Number: 3392519
GE Dryer(model#DDE7100MBL): Not heating at all, ohm tested the safety thermostat(thermal fuse) for continuity, found no continuity which means its out.
Here’s the safety thermostat(thermal fuse) for this model:
Manufacturer’s Number: WE4X800
GE Dryer(model#DBSR453EB2WW): Not heating, found the heating element wire broken.
Here’s the heating element for this model:
Manufacturer’s Number: WE11M23
Estate Dryer(model#IED4400SQ0) made by Whirlpool. Not Heating, did an ohm test for continuity on the heating element, found no continuity. Installed new heating element, worked great!
Always unplug the dryer before doing a ohm test for continuity!
Manufacturer’s Number: 279838
Westinghouse Dryer(model#DE650JDD1): Dryer drum not turning, motor is just grinding when you push the start button. Motor bearing is bad.
Here’s the motor for this model:
Manufacturer part number 5300603185 is RepairClinic item number 94
