When I arrived I pulled the refrigerator out from the wall, then unplugged the refrigerator, then removed the compressor start relay from the side of the compressor and used my digital multimeter to ohm test it, I set my meter on 200 ohms, and my meter’s numbers didn’t change when I ohm tested it, and that means its bad.
Normal ohms should be 12 ohms or less, usually around 5 ohms. I installed a new compressor start relay and the compressor came right on and started cooling. I also cleaned the customers condenser coil. located underneath the front of the refrigerator, behind the kickplate grille.
Here’s the compressor start relay for this model:
W10920279 Relay-Strt
