I went to the customers house and found the dryer running but not heating at all. The Ignitor was not even turning on. I unplugged the dryer from the wall outlet, then took the dryer apart and ohm tested the thermal limiter that’s located on the burner tube and it ohm tested bad, no continuity at all.
I ordered and replaced the thermal limiter and it worked good and started heating.
Here’s the thermal limiter for this model:
137539200 Limiter
